Strange pattern on frame
TheDoctor
The TerrorVortex
The different types are purely cosmetic (gross oversimplification alert).
Anything carbon is made from a few layers of unidirectional carbon, each in different directions. Like the grain in plywood, where each layer is at right angles to the next one. You then apply a cosmetic top layer, like the veneer on chipboard furniture.
Andywinds
Andywinds
Well I've learned something new today, thanks.
Globalti
If you bear in mind that the carbon tube is formed by a long internal bladder being inflated and forcing the carbon weave into the mould, you'll understand that pattern. It will then have been rubbed down, lacquered and re-lacquered.
Andywinds
Andywinds
So does the carbon sort of melt and leave that pattern? I've seen some carbon finished where it looks like more of a weave effect.
Globalti
No the carbon is a coarsely-woven cloth with a warp and weft. It is soaked in resin and forced into the mould under high pressure while the resin goes off. The resin forms the shape of the bike but the embedded carbon cloth gives it the incredible structural strength, just like reinforced concrete. Different weaves of carbon will create different patterns, which we aren't accustomed to seeing because most frames are painted.
Unfortunately the resin tube walls aren't very robust against point loads and impacts and are crushed relatively easily when compared to their structural strength, which is why some people still distrust carbon. But rewind about 30 years and you'll find people fretting about the fragility of very thin-walled steel tubes.
Andywinds
Andywinds
Right ok, so really carbon on it's own is a thread or sheet of cloth like material?
Globalti
Very nice. I wonder if they'd make me a suit?
So this runs counter to the doctor's advice, so which is correct?
BB
TheDoctor
The TerrorVortex
BB
The tube is made up of layers, then formed. Where I work, things are made on the outside of a mould, but it's the same principle.
But your previous post said it was purely cosmetic like a veneer topping whereas globalti's says it is the result of the material being pressed into the mould. It can't be both.
