roadrash
cycle chatterer
- sitting on the edge of wigan pier
with regards to the lighting..... why did you buy something you did not want.
Yes but as said - on my previous fixed gear I don't feel instability without a load on its rack, and if any, certainly by far not the difference that the new bike exhibits.My fixed gear was hard work when I started loading it up with stuff for the commute. Didn't notice it after a while, but oh my, did the fixed and the two other road bikes feel very different, ie. fidgety. I was used to a laden bike.
You might be too used to a loaded up bike.
I understand and appreciate your point of view, also thanks for the example case, but occasionally it happens that I need a clear rack, and the bike then suddenly starts to become much harder to control, so badly that I have to slowdown in order to feel safe enough. Recently the rear rack had some lose and lost bolts so that I had to take off everything for a while, and I was hard-reminded of it the next ride. It's remarkable how different it becomes.To the OP, while it is nice to understand why and how things work,
given you bike is fine with a load in the right place, I would just enjoy
the bike.
When I was young I had the most expensive racing bike in the shop,
don’t even remember the make, and it was the most difficult bike to
ride, If you coughed you would change direction, the one I have now cost 200.00
second hand, it’s a treat in comparison, and super comfortable.
I have had goes on other bikes, expensive and not so, and everY one of them
rode differently, that’s just how things are, and why people who know will
always advise you to try before you buy, it’s the only way you can be certain
whether any bike is the bike for you.
Regarding your current situation, try a shorter or longer stem,
even try a fork that would leave the bike more similar to a bike
you have that does not have the issues you currently have.
Fork trail and stem length can play a huge part in how a bike behaves,
I once put an 80mm stem with 3 degrees more rise on an old bike instead of its 90mm stem,
everyone told me it would be even more twitchy, but I did it, the bike was
completely different, and to everyone’s surprise the twitchyness was gone,
the bike was twitchy because of me, it wasn’t turning in unless I gave it a quick pull
and I was overdoing it, the shorter stem did it for me.
I didn't buy a rear light, I bought a bike and the rear light was a part chosen by the bikes producer.with regards to the lighting..... why did you buy something you did not want.
ahh , so if you didn't buy it, are you saying they included it free of charge
No its price was included in the basis price of the bicycle, an item chosen by the producer so I didn't "choose" the rear light, just like I didn't choose the spokes brand/model, the rims, the handlebar, the saddle, the inner tires, the brand/model brakes, the front light, the dynamo hub, maybe this list helps you to the point I made.ahh , so if you didn't buy it, are you saying they included it free of charge
Well, since alot choices of the producer and dealer turnt out to be crap, and since I searched and found better, some of that "everything" ceased to be an issue. Not exactly a "feeling" either, the bicycle sold and delivered "as is", needed new chainring, new chain, new axle, new bottom bracket, after a few months. The replacements held out over a year, that chain I found and mounted myself, held out 18 months, most of that time with a 5 mm off chainline, which I also solved myself, along disc mount - dedicated spacers. Time to distance as 50-60 km/day.I have a feeling everything is someone else's issue.
That sounds terrible for a new bike to be out of line like that, and all the otherWell, since alot choices of the producer and dealer turnt out to be crap, and since I searched and found better, some of that "everything" ceased to be an issue. Not exactly a "feeling" either, the bicycle sold and delivered "as is", needed new chainring, new chain, new axle, new bottom bracket, after a few months. The replacements held out over a year, that chain I found and mounted myself, held out 18 months, most of that time with a 5 mm off chainline, which I also solved myself, along disc mount - dedicated spacers. Time to distance as 50-60 km/day.
This stability issue, is 1 problem not solved. Mostly because it's not a big one, only that it surprises when circumstances bring it back on.
So, what else can I conclude, than the phrase "do it yourself - do it good", instead of relying on dealers?
No its price was included in the basis price of the bicycle, an item chosen by the producer so I didn't "choose" the rear light, just like I didn't choose the spokes brand/model, the rims, the handlebar, the saddle, the inner tires, the brand/model brakes, the front light, the dynamo hub, maybe this list helps you to the point I made.![]()
It wasn't frame but chainline out of line.That sounds terrible for a new bike to be out of line like that, and all the other
problems that resulted from it, I would have sent or taken it back and looked for a refund.
You do get an odd product that comes out wrong, I used to work in manufacturing steel
products, and if anyone got a bad product, there would be question regarding it
being changed for new, or a refund, you really should have sent it back.
To get a bike out of line from new is really bad, because the frames are assembled in
a jig to hold them exactly in place, so something obviously went badly wrong in
the making of your bike, and it should have been sorted.
I bought a frame, with some chosen parts, and the choice of other parts delegated to producer/dealer, relying on their expertise...nope, it just confuses me more, I never said you chose them,...I said why did you buy something you didn't want ….even though we all know you chose to buy them , unless you just bought a frame and they gave you all the other components free , which of course didn't happen.
if it still confuses you it must be a language problem
Your problem isn't a language problem so it's your own problem then.nope no language problem , unless the lights were given to you free then you bought them ...simple as that
