sram rear derailleur issues after chain snapped.
jowwy
Not here offten enough to argue
Not sure what you mean by that.
By hand I can move the cage easily no restriction at all.
On my other bike there is tension.
At the back of the mech is there a plastic button with a lock sign on it???
jowwy
Ajax Bay
East Devon
I don't understand that if this is my problem and its knackered, why did I not get an inkling about it after putting back the chain to complete the ride.
Gears perform remarkably well even when the tension on the lower run is poor, providing you ride with care.
Have you checked rear mech alignment, it is very likely to be out.
In the context the OP describes, why do you think "it is very likely to be out"?
screenman
Quite often a chain breaks when under side loading. Besides that I am yet to check a mechanism alignment that does not need tweaking for optimum performance.
afl2
afl2
North Wales
Here are clearer pics.
jowwy
Proper busted up.......
Tim Hall
Crawley
What happens if you hoik the cage back into its proper position? Does it stay there? If so it could just be a bit of grit in the wrong place.
