Jimmy Doug
If you know what's good for you ...
Yay! Sorted!
Went round to the LBS yesterday and bought another chain. Fitted it this morning with no trouble at all. I think the key to my troubles was this:
When I'd split the chain on both occasions I broke it at the place I thought I needed to and didn't realise that with chains you have to work in pairs. Found this video last night which really helped me to visualise the situation:
This morning I got to it early and was amazed how easy I found it this time! Now I really feel like a dummy for making something so straightforward into a mountain.
Anyway - here's the situation now in the upper/upper combination. If you compare it with how it was, you'll see that the deralleur is under less stress (according to the video about you should not count the Powerlink when calculating the number of links extra - ie, it's two links excluding the Powerlink).
Before:
After
My LBS gave me another tip: he said that with the chain in the largest sproket at the front and the smallest at the back, the middle ot the cassette, and the centre of the jockey wheels should form a line. This looks good to me (although the first jockey wheel doesn't seem to be on the line which may mean the chain is too long still):
The only thing is, he didn't have any SRAMs left. He sold me instead a Selcof SLC-S8, which looks to me to be a cheap copy. He's a good fella in that shop - he only sells good stuff - but I'd feel a lot more comfortable if it were a genuine SRAM.
Oh, and one more thing, he advised me to only have one Powerlink in any given chain and no more. As Colin said, is this an admission that these Powerlinks aren't all that strong?
Thanks once again guys - I couldn't have managed without you.
The normal kind of chain like that is made up of alternating inner and outer links. The outers hold the pins which go through holes in the inners. You don't have a choice - you have to alternate them and Powerlinks are outers.
Before:
After
