The chicks dig a big, but firm and shapely butt on a man.
This topic comes up again and again so obviously there is a fairly fundamental misunderstanding as regards what's needed to become a faster cyclist.
When you're cycling up a hill, it's very similar to climbing up a flight of stairs. The forces involved, the repetitive nature, the "rpm" are quite similar. Pretty well everyone can climb a flight of stairs with their current muscles. Pretty well everyone can climb a flight of stairs at, say, 80 stairs per minute. But climbing 20 flights of stairs at that pace? That's hard to do.
But the question is why is it hard to do? It is nothing to do with how strong you are. You've already shown you're strong enough by being able to climb one flight. Of course you get out of breath and the legs start to burn with lactic acid build up. That's your cardio vascular system limiting how quickly you can climb 20 flights of stairs. Exactly the same cycling up a hill. So if you want to climb 20 flights of stairs more quickly or cycle up a hill more quickly, your cardio vascular system is what's holding you back
Unless you ride fixed/SSBroadly yes, but with bikes your have the added complexity of gears. In theory, more power allows a higher gear which allows you to get up the hill faster than someone else at the same cadence but in a lower gear.
Unless you ride fixed/SS![]()
In my limited experience of fixed/ss and proper hills1 (I am a coward) then strength is even more important as you don't have gearing to get you out of trouble.
1. Definition of 'proper hill' for a Milkfloat is 2% over a distance greater than 50m
Where do you think the power comes from?
Strength is not a limiter on a bicycle - the number of gears is irrelevant.
Fine, then you won't mind demonstrating this by climbing a decent hill in a very high gear, ideally with a good cadence. Of course it is a limiter, it may not be the most important limiter, but it is still a limiter. Obviously a balance is required for optimum performance.
