I think you need to draw a diagram - you haven't understood it.
I think it rather funny that "you cannae change the laws of physics" but you are trying to!![]()
Even better, if there is a small boy handy at the bottom of the climb you should get him to ride on your shoulders.
The point is moot anyway, because NOT holding onto the bars is not an option. Assuming you accept that, then the only other question is how much more force is it possible to apply to the pedals by pulling up. Some, but not much, by definition. Principally because of the angles of the forces, as mentioned earlier.
Nice try at deflection, but we're not talking about pulling up through the pedals
Have you changed your mind and now accept than a 90kg rider can apply 100kg force to a pedal?
I mean pulling up on the bars. Nobody is talking about pulling up through the pedals.
You will only exert anything like a maximal force on an object while it is stationary. As soon as the pedal starts to move (ie a split-second later), the application of a maximal force is no longer possible, regardless of how much you pull up (on the bars). Could you perhaps remind yourself what the thread is about before you go off on a complete tangent?
If a 90kg rider is applying 100kg at the pedal, then he only has to apply a pull of ~10kg at the bar.
Your rationale is utterly absurd. Think about it.
And yet still wrong and still no clue. Did you even watch the Chris Hoy video? Can you even imagine how much force he is applying to his pedals for the first half dozen pedal strokes?Stop asking the obvious. When you stand up, you are pushing against a stationary object (ie the floor). Look at how the forces are directed through a bicycle. You will never put your entire bodyweight through one pedal, even if you wanted to.
Do you think he squats 227kg (or at least used to) just to push 90kg of force down through the pedals?
