Richard A Thackeray
The front brake on my CGR feels odd
It's almost as if there's air in it
However, it's not been touched as a system
For the record, it's on
RS505 'brifters'
RS785 Calipers
Metal 'sintered' (Shimano) pads
Initially I thought
1. it was mud, as I cut through the woods/along the river (Calder) bank on it, & that some had got onto the pads
2. as I keep it in the male changing rooms, in one of the departments, that it had possibly been over-sprayed with a deodorant the day before (etc...)
On arrival at work this morning, I pulled the pads, they felt slightly glazed
I also cleaned the disc with a couple of sterets (the IPA wipes, that are used on your arm, before an injection)
Riding home showed no discernible difference in brake performance
The pads are quite worn, I normally change them before this point.... mainly due to liking a short lever travel, rather than wear
But these may have gone further??
(I hadn't been able to get the correct pads for a couple of months)
So, does the panel think it's really due to extended pad wear, & there's no surplus of fluid to overcome this (lever quite close to bars too)
Or, another fault???
Thanks in advance
NB;
I've never had cause to bleed them
There's no sign of a fluid leak
I used to use Magura hydraulic rim-brakes on my Pace RC100, so used to those)
RS505 'brifters'
RS785 Calipers
Initially I thought
Thanks in advance
NB;
