Rule no 1. Never try and work with unlubricated spokes and nipples. Lube the spoke thread before putting the nipple on and, lube the inside of the rim hole where the nipple contacts the rim. For the latter, a cotton bud works well.
You say the spokes turned, but did they turn completely or did they just wind up? You can hold a spoke with a pair of pliers but never, ever allow it to slip inside the pliers. The resultant scratch will cause a stress riser and eventually the spoke will break there. The break will look like a clean laser cut.
Keep on trying, it is a nice challenge that will teach you a lot, including how not to design wheels.
Good luck. Just persevere, you'll get there. But, be patient and systematic.The spokes just kept turning in the holes in the rim, so all my adjustments were doing absolutely nothing.
Obviously these nipples/spokes were not lubricated when constructed.
I held the spokes with pliers and a hard rubber sleeve to prevent scratches, so fingers crossed.
Kick the dog.When I'm building wheels I just tip my nipples into a small dish with some EP90 (gotta love that smell) and pick them from there as I lace up.
If, when moment is applied, the nipple is not turning relative to a J-bend spoke, then the spoke will twist. So the longitudinal tension in the spoke will be the same, the rim will not be pulled in the direction desired and the spoke will develop torsional stress, in addition to its tension (stress). A problem you don't get with straight-pull spokes.as I turned the nipples the spoke turned as well - a problem you don't get with J-bend spokes.
There are guitar tuning apps for your smartphone.It's a Fulcrum Racing Sport DB wheelset which I've been told is OK but nothing special.
@Yellow Saddle, that explains why I was worried about the tension in the 7 left spokes. I have a tin ear but will try to follow your tips at the weekend, which is my first opportunity.
I suspected the spoke pattern was for show rather than purpose, but didn't know enough about spoke pattern to say.
