Drago
- Suburban Poshshire
Where will they fit the spoke reflectors?
You'll find a very hard to please audience of über sceptics here, but don't let that put you off. Just don't ask for money!
Me, I like reading about this kind of stuff, be it doomed to failure or ground breaking.
I'm very open minded to all kinds of new innovations.Then again, you're clearly not even open to the concept of trouserless dogs. People in glass houses ........
How are you protecting the teeth from damage by the elements? the same way the chain and gears are protected on bikes
You seem a bit vague on this point. This is the most crucial aspect. A lot of "new" designs that have tried and not quite succeeded in the past (leaf springs for spokes, variable size chainwheels etc) have done so because of the constraints of traditional materials (and the superiority of the existing design), and it's entirely possible that new materials may see them make the step from perennial non-starters to success.How are you dealing with the increased rotational mass (no spokes means stronger rim required means more weight at the outside of the wheel)? We will use nano carbon or carbon fiber so it is as light as possible
Show us it then.Hey everyone,
I am part of a new company which is bringing to market a revolutionary new product... A spokeless bike!
In order to do this the gear will be connected to the bikes rear wheel rim and will run through a series of teeth which turn the wheel. This gear will be positioned at the rear wheels 8 O'clock (If you are looking at the CycleChat logo) and will cause the bike to go faster than if it was positioned normally. The suspension is not affected by the removal of the spokes and this design is less likely to have a tyre bend than a traditional design as the impact is more evenly distributed around the wheel. The bike will be lighter than a traditional bike will have improved steering and will have improved braking in comparison to a traditional bike. There will be an easy release system on the mechanism in case of damage.
Our design can be used on more than just bikes it can also be used on cars, scooters, segways... pretty much anything with a wheel!
We are very excited about this product but we would like to hear some feedback from you all, both positive and negative, if you have any questions about it please comment below and we will get back to you as soon as possible.
The prototype is currently being built, I will upload pictures once it has been finishedShow us it then.
