But how does the lacing pattern affect longevity i.e Radial, single cross, 2 cross, 3 cross, (standard) 4 cross, (my favourite pattern for rears) or 5 cross, (used on tandem 40 spoke hubs) or the one I got John at Bob Warners to build for me (4 cross with plain guage on the drive side and double butted on the non-drive side) BTW he said you've been on that internet haven't you but built it to my idea anyway (I blame Sheldon Brown, his idea
Radial, as far as I understand offers no noticeable advantage over tangential spoke lacing, Some front low spoke count wheels can't have X spokes (too few spokes) so they have radial. There is a small increase in radial stiffness and also a small gain in lateral stiffness. Somebody did some testing and found that radial lacing with spoke's heads in increases wheell stiffness by 13% over spokes with heads out. Maybe such increase is not desirable on very wide flanges, I don't know.
There is a school of thoughts that believe a radial pattern on the NDS and a X pattern on the DS is a good combination to increase the spoke tension on the NDS. This is based again, on the brace angle, but this time the spokes heads on the outside of the flange. I haven't tried this myself and I was going to put it to the test on my next set of wheels but I changed my mind
I can see, in my mind, a small gain in tension of the NDS spokes but I can also see a small lost of lateral stiffness. Some factory wheels are built this way and some factory wheels even put the radial lacing on the DS..... where one expects to see pulling spokes for torque transfer. (A topic for me to investigate one day
The disadvantages are too much strain on the hub flanges. Some hub manufacturers specifically say no for radial lacing.
As for plain gauge spoke, I don't use them. I think the advantages of using double butted spokes are there for everybody to see, it's not a secret, I do remember reading the same thing but a long time ago, before I started building wheels, not sure if the advice is still there. Even to this day some people still believe in using 2.0 - 1.8 - 2.0 on the drive side and 2.0 - 1.5 - 2.0 on the NDS perhaps is the same school of thoughts but my guess is that is driven by weight winnies eager to save a single gram
5 cross? Wow.... is there any advantage over 4?
There is a paper written by Henri P. Gavin that might be of interest to you.
The conclusions are:
"CONCLUSIONS
Requirements of strength, stiffness, and low weight are satisfied in bicycle wheels by combining
a light-weight rigid rim with pre-tensioned wire spokes. In many rear wheels very high pre-tension
stresses in half the spokes are required to maintain an asymmetrical shape. The radial, lateral, and tan-
gential stiffness of wheels with various spoke sizes, spoke geometries and rim stiffnesses is presented.
The behavior of bicycle wheels subjected to static radial loads can be accurately modeled by idealizing
the system of interlacing spokes as a linear elastic foundation of uniform stiffness per length of circum-
ference. The spoke pattern affects the over-all radial stiffness of the wheel more than it affects the spoke
strains. From a theoretical analysis, a numerical analysis, static experimental analysis, and in-service
measurements, the spoke strains appear to be insensitive to the pattern of the spoke lacing. From a
numerical analysis, the spoking pattern has the greatest impact on the spoke strains when the wheel is
subjected to large lateral loads, such as during cornering. In this case, wheels with longer spokes have
lower strains than do wheels with shorter spokes. Small variations in measured spoke strains between
the wheel types under actual riding conditions, are attributed to variations in un-measured loads. The
extreme spoke stress cycles in the road test experiments were on the order of 150 MPa. Each cycle at
this stress level shortens the remaining fatigue life by one one-millionth of the total fatigue life. Larger
stress cycles, due to large lateral loads, for instance, could shorten the fatigue life considerably. Future
work could therefore be directed toward:
• Measurements of spoke strains due to high lateral loads, and,
• Non-linear modeling of spoked wheels subjected to spoke-slackening loads.
The fatigue resistance of the spokes, the spoke diameter, the arrangement of the spokes, and the
stiffness of the rim influence wheel stiffness and fatigue life. Wheels with 2 X, 3 X, and 4 X spoke
patterns all have similar spoke strains when subjected to radial loads. The fatigue resistance of spoked
wheels to steady cycling loads is very high for most typical service conditions."
The whole paper:
