DooDah
- France, now Northamptonshire
Hi all,
Being mechanically challenged I had the front and rear derailleur adjusted by my LBS after owning the bike for 4 months. The gears had started to have problems due to cable stretch. The bike was running sweet, but now when in the largest cog on the front and smallest on the back the chain rubs slightly on the outside edge of the front chain guide. Also seems to rub when on largest front cog and largest rear cog, but on the inside of the guide. The front derailleur does is not marked H and L so I am not sure what to adjust (and to be honest how to do it). Is this the problem or could it be something else.
Last time I attempted any adjustments I made it much worse, hence why it went to the LBS. This time though I would like to sort it out myself.
