black'n'yellow
mainly torsional on the l/h, torsional and axial loading on the r/h...
'That enormous'?If the loads were that enormous, and if the chain was so tight that it caused the frame to fail, then the gear hanger or mech would have failed long before the chain stay or BB gave out. Hangers are specifically designed to be one of the first failure points in order to prevent stuff like this from happening.
blah blah..... it sounds like too much pressure was put through the frame causing a fail. On this basis I'd expect Specialized to replace it.
I've been thinking about this while I was having lunch, and, in fact, if the chain was that bloody tight you wouldn't even be able to turn the cranks - the bike would be unrideable.
Replaceable hangers are designed to fail when a bike is dropped or otherwise bashed on its mech - to protect the mech and frame - not to allow for the consequences of a too-short chain.
Sorry but it is entirely accurate. I'm not guessing, I know. And, from the OP's account, it's pretty clear to me what actually happened.sorry, that's not entirely accurate. The hanger is designed to fail in a situation which would otherwise result in a bent chainstay/seatstay/dropout, or busted mech - and that could include chain/transmission related issues, as well as impact damage. I've replaced plenty of bent hangers on bikes which have not been dropped or crashed. It's the reason why the hangers on most aluminium or CF bikes are made out of relatively low grade ally, or why the dropouts on good Ti frames are made out of CP titanium rather than the 3AL/2.5v stuff that the rest ofthe frame is usually made from. It's entirely reasonable that the hanger should have failed first, in the situation described by the OP.
In any case, we are all just speculating, because it's not completely clear what actually happened.
Well no. I'm really no expert at this so don't know why I got involved but the way I see it is that regardless of the length of the chain an amount of pressure has been applied to the chain between rear cog and front chainring with the effect of trying to "drag the rear wheel" forward. If this has caused the chainstay to break then it suggests the frame is faulty surely.Not to replace it shurely.
