Andrew_P
In between here and there
Barely any clearance really a few mm should do it. My only complaint is that the metal on the brackets under the brake calliper suffers with fatigue and then gives up usually mid ride. I hid my rear section behind a brick wall couldn't get it into my rucksack and went back and it was gone, gutted.
I used two sets last winter and so called spring, probably 3k+ miles just about to buy a new set still good VFM imo just to save not getting soaked just when the roads are wet but not raining. I have enough brackets now to change them every 1k so hopefully will just use one set.
