- South Manchester
How handy are your DIY skills - file etc... key to cycling is BODGING !
I can say I haven't had these problems but then I've only ever fitted to frames with a generous clearance. The only workaround I've had to do was on a set of forks where the bolt area is molded and recessed. So if you fit the bridge bracket flat, inside the recess, then it can't be raised above a certain point. To get around this I used one of the spare rubber bungs from a set of Hope Grip Doctors. I cut a pice about double the depth of the recess and used it as a rubber washer. This meant I could have the bracket set higher and get it tight enough without interference from the recess. It actually sits flush with the outer edge now as the rubber compressed when the bolt was tightened, that was why I cut it to double the size.
I know this may not help your specific problem but I think you're on the right track with the key being to get the bridge bracket positioned correctly first. I don't have any caliper brakes so it's not easy to envisage your problem. But is there any possibility you can resolve it via a longer bolt workaround. I did this on a previous bike, swap out the existing caliper bolt for the longer one and fit the brake as usual. I then used a second nut and washer to fit the SKS bracket and was able to position it much more easily and, more importantly, ensure that I got maximum clearance.
1603916 said:Ditch the metal bracket that attaches to the brake bolt. Drill two holes in each side of the mudguard so that two zip tie can go through, one each side, and round the seatstay bridge. It gets a good 3-4 mm more clearance.
It is also much less prone to rattlyness
Mr Remings - Have you got a Giant Defy or similar Giant bike?
If you have, then the SKS will not fit.
Giant make their own guards to fit the Defy/TCR/OCR range of bikes.
No fault of SKS I'm afraid.
it's perfectly normal for the stays to be cut. just use the cutting teeth on standard pliers, they're only mad of soft material.
You may not like the instructions but the materials are top notch - SKS stays are made of stainless steel and effing hard it is too - I had to borrow an angle grinder as the stays were wearing out hacksaw blades at one blade a cut.+1.Oh no they're notYou may not like the instructions but the materials are top notch - SKS stays are made of stainless steel and effing hard it is too - I had to borrow an angle grinder as the stays were wearing out hacksaw blades at one blade a cut.
