ChrisEyles
- Devon
I had a look, and seems like most dingle sprockets are for fixed gear track hubs.
Extra wide SS sprockets also seem to only be available up to 21t or 22t, which makes perfect sense for a SS running off a ~32t chain ring, but isn't ideal for what I'm planning.
I guess I could do something similar using a 32/18 gear on the middle ring and a 24/26 gear on the granny ring, and ditch the 42 chain ring... but still wouldn't be able to get a 26t SS sprocket for the granny gear where it matters most, and I'm thinking the higher tooth count I was originally planning on is probably going to wear better and be less likely to skip under pressure too (plus let's face it, being in the "big ring" on a MTB always looks cool
A shame as a 23t,34t dingle sprocket would be the perfect solution.... I would just probably be the only customer for it.
I wonder if it would be possible to use the pins that hold the cassette sprockets together to link the 23t and 34t sprockets... probably the length and position of the threads will be wrong but might be worth a go.
I think if the cassette body turns out to be steel on my hub I'm just going to give it a go with the 23t and 34t cassette sprockets.
)A shame as a 23t,34t dingle sprocket would be the perfect solution.... I would just probably be the only customer for it.
