MartinC said:If some people have the perception that it's easier then that seems credible to me as does the converse too.
hubgearfreak said:you're right - if one believes something works, then for them, it works.
in medicine it's called the placebo effect.
MajorMantra said:By the way hgf, you make it sound like I've never ridden a freewheel.
MartinC said:a very complicated .... Do you know enough about this system
hubgearfreak said:do you truly believe that the momentum of the bike can move your legs without effort expended by you or at the expense of the momentum, really, honestly?
MajorMantra said:The forward motion of the bike keeps your legs turning through the top of the pedal stroke making it easier to keep going up a hill.
hubgearfreak said:here you go.![]()
MajorMantra said:TANSTAAFL
kyuss said:the higher end if running it fixed gear as they tend to be a bit easier to climb with
Hmm... whilst both will take the same amount of work, would the fixed not help carry the foot through the dead spot, a point at which you can't put in much power, by using some of the energy stored when you are going through the down-stroke?hubgearfreak said:so what i took issue with is the oft repeated myth that fixed is easier to climb with
hubgearfreak said:when in actual fact getting a mass (bike & rider) from one level up to another level (ie. uphill) will take the same amount of work
brodie said:This thread is going way off topic...
If someone is letting the momentum of the bike and rider push their feet round, then they are actually slowing down the bike!
brodie said:Funny how the "flywheel effect" only seems to work uphill.
