Should I refurb or send for scrap metal?
newts
newts
Isca Dumnoniorum
My first attempt at wheel building was quite satisfying as the wheel began to tighten up. 70 year old rims aren't perfect, they're within 1.5mm which i think will suffice for a runabout bike. It was a slow process & average spoke tension is around 110kgf & feels tight.
newts
newts
Isca Dumnoniorum
Which 27" tyres & inner tubes would CC'ers recommend for this bike?
T4tomo
you can use standard 700c inner tubes. I use Panaracer Pasela PT on my vintage bikes - good tyre with a gum wall version. come in both 700c and 27", both 1 1/4 and 1 3/8h depending on frame clearance. front fork looks like loads of clearance!
newts
newts
Isca Dumnoniorum
I thought 700c inner tubes would suffice, theanks for confriming.
The panracer looks a very nice tyre.
I'm looking to go budget with this bike, should I compromise on tyre cost?
What has happened to the frame ?
I would brush some cellulose thinners on the blue paint with a toothbrush and wipe it off with a rag .
I would also treat the rust in a similar way but using some rust removing gel.
Have a look at my Dawes Red Feather Find post for rust .
newts
newts
Isca Dumnoniorum
I tried brake cleaner fluid yesterday & the blue paint just laughed at it.
The frame has taken a back seat whilst I was cleaning up the wheels.
Chrome bits are soaking in an oxalic acid bath, rust is diminishing slowly.
Cellulose thinners will destroy most paint finishes . You could even try petrol , E 10 can affect paint and plastics .
newts
newts
Isca Dumnoniorum
I tried the tin foil method to clean up the chrome but it was too much elbow grease. The rusty bits have been soaking in oxalic acid for a couple of weeks (dsrt spoon of barkeepers friend in a pint of hot water) & have screubbed up well.
