w00hoo_kent
One of the 64K
- Maidstone or Greenwich
I think I've seen you mention hex keys, but not torx keys, if you are swapping a disc over then it'll almost definitely be held on with torx.
Things I've ended up needing from doing similar work on the Sirrus (going Tiagra to 105 mostly) chain tool & cassette tool to remove the cassette (sounds like you've done this already), Torque wrench to do things back up again, crank removal tool to take the cranks off. Set of hex keys, set of torx keys. I've not fiddled with new cables yet (a friend did that for me while I wasn't around) so haven't had to do cutters. Decent small screwdrivers for setting up the mechs. Grips to keep the cables tight. Threadlock to put on the disc bolts when reassembling everything.
