SkipdiverJohn
Deplorable Brexiteer
- London
Ah, but you keep forgetting that you have more than a foot in height on me, are close to double my weight and have far longer legs! You have the ability to put our far more "oooomph" than me, hence your choice in gearing.![]()
No doubt I am a lot bigger and stronger than you, but that in itself means little in isolation, because my extra strength is used propelling my extra weight and aerodynamic drag around that you don't have to deal with. In terms of power to weight ratio, I wouldn't like to claim a big ugly bloke is necessarily guaranteed to be proportionally more powerful than a petite woman, if you were to go on watts power divided by bodyweight. Where I do think you probably have a disadvantage, is that if you need shorter cranks for either biomechanical or ground clearance reasons, the shorter levers mean your torque input at the pedal will be higher for a given output power, than someone like me who mainly has the standard default 170mm cranks - assuming the same mathematical gear ratios.
