Amanda P
- York. Well, York-ish...
peanut said:good point Norm. Most people don'r realise that the more you do up a vice the more it will squash the seat pin out of round and actually make it tighter in the seat tube.
It is a good point.
However, if the seatpin is the type with the seat clamp cast onto the top, gripping the clamp part would not crush the circular-section part.
But it sounds as if Zipply doesn't have this type of seatpin. I'm guessing it's just an alloy tube that takes a separate seat clamp on its top? Correct, Zippy?
It is alloy, isn't it? Is it dull, alloy-looking metal, or is it coloured? Some alloy seat posts are anodized. Or is it shiny chrome-plated steel?
How much seat post is showing above the frame? If there's lots, crushing the top probably wont' deform the part of the tube near or inside the frame's seat tube. If there isn't much, crushing it will deform (oval-ise) the part inside the seat tube, which will make it harder to get out, so don't crush it!
If it crushes easily, it's thin, soft, drawn alloy, and you may find that, when you twist the frame with the seat post in the vice, you just twist and tear off bits of the seat tube: bad news.
Whacking the seat post down into the frame may seem like going the wrong way, but Peanut's right: it's about cracking the collar of gunk that's gluing the post in place. Once you've cracked that seal, it may move back up more easily than it did before. Or it may not - but it's worth a try, you've little to lose at this point. You can apply a lot of sudden force on the top of the seat post with a lump hammer!
After a soak with caustic, try all the "brute force and ignorance" tricks again - twisting (twisting is important), pulling, hammering down. Once it starts moving, in any direction, even fractionally, you're winning.
