Mobytek
That's taking into account your Ape factor - if your hight is the same as you arm span then you are equal, plus or minus gives you posative or negative ape factor.
So effectively arm pit to finger tip should be the same as crotch to toe (round the heel) so will also be approximately in the right field.
