bad boy said:Sorry if this sounds stupid but by cutting the spoke does that not just remove the spoke as opposed to the rounded nipple !?.
I guess you would still need to use a screwdriver to unscrew the nipple from the rim and as Jimboalee pointed out if the spoke is filled flush you may need to use something else.
accountantpete said:The nipple only sits on the rim through friction.
You can do two things - either cut the spoke and get a new spoke and nipple or
unscrew the nipple and then get a relacement nipple.
The thread for the nipple is on the top bit of the spoke, it shouldn't be attached to the rim.bad boy said:Thank you pete I thought there was a kind of thread in the rim the nippple screws into, but I take it that by cutting the spoke the nipple will just simply come out
jimboalee said:Mole grips.
