- Inside my skull
You go 40mph down hill on a tandem?? You are pretty brave!!
That’s pretty slow downhill for a tandem.
I have TRP Spyres on a QR wheeled bike (and I had the same before on two other bikes), so not sure why that’s an issue?
When we get a bike through the shop which has a rubbing brake the first thing I do is put the bike on the floor, open the quick release and let the weight of the bicycle centre the wheel, that cures the problem quite often. You just can’t reliably centre a wheel in a stand or with the bike inverted.
Rotors warping isn't really something unusual. Truth to the matter is, bicycle rotors are just to thin and flimsy - and the manufacturers know it. Producing something that would actually work would make it significantly heavier and be bad for marketing, so they don't. Much easier to tell people they're using their brakes wrong - well, with all due respect, if you're going down a 20% gradient with potholes and occasional gravel (i.e. half of British hills), good luck with not occasionally dragging your brakes.
Yeah, all those pro cycling teams don't have brakes that "actually work". Right!bicycle rotors are just too thin and flimsy - and the manufacturers know it. Producing something that would actually work would make it significantly heavier and be bad for marketing,
I think you've slightly exaggerated here. When referring to 'not working' I meant it in the context of this topic - i.e. discs warping. Not actually not being able to stopYeah, all those pro cycling teams don't have brakes that "actually work". Right!
Cos I’m fat and ride down big hills… rims don’t stop me!
