Road bike to flat bar
Well this is finally done, thanks to @jefmcg for helping me strip the two frames as much as we could and to a very helpful LBS for putting it all back together!
The wheels I was going to use on the roadbike won't take an 11 speed groupset so used a later model of the same wheel instead (which I was going to sell)
I have a bunch of cable Inners unused and I've passed Halfords 28 day returns which is annoying
Otherwise I had most of what I needed, new bartape was required
Photos when I've fixed the crud mudguard which annoyingly came apart trying to remove the bike from the car!
Five but trying to reduce to 4
I had forgotten how much I hate crud guards! I doubt they'll last long on the bike, flimsy crap
I assume they want pictures of 5 bikes. I can attest to their existence.
Ah ok I didn't know what post you were referring to ;)
Here she is
Brandane
Costa Clyde
@vickster ; I am planning to do something similar with my Specialized Secteur drop bar. I believe the frame is the same one as used on the Sirrus flat bar bike anyway; so all I intend to do is take off the drop bars, along with the Shimano Tiagra shifters. I will be buying MTB bars, along with Shimano Deore 9 speed triple MTB shifters, and a pair of Shimano Tiagra brake levers.
Did you have any issues with compatibility using flat bar brake levers with road bike brake calipers? I have read somewhere of differing pull ratios causing problems.
I'm not sure how apt it is but the Giant Rapid uses a flat bar with side pull callipers.
All my kit was SRAM, no issues at all. Just bought shifters and brake levers compatible with the rest of the kit
Only issue I had was that the bike was too small as a flat bar and probably sold to a friend who is 4 inches shorter than me. Even with a 130mm stem, too cramped (friend will ride with a 90/100mm stem)
