It depends on personal fitness etc as well as the hills ridden, I doubt that the Schleck brothers have a triple between them !
I'll be looking for a quadruple chainset soon![]()
Along with a suitable chain keeper of course!I was referring to ratios and chainrings, if you were commenting on my post.
The schlecks would always go for a smaller ring and narrow casstte.![]()
I think what everybody 'else' uses is pretty imaterial to the OP as Alun has stated everybody s capacity's for hills will be different. The difference between the current bike and the new bike will be marked especially with a decent set of tyres on. IMO this may be the main factor in determining his choice.
The other thing to consider of course, if you are riding in somewhere like the Pennines. Will the 50 on a compact be big enough for the job on the descents ?I'm a great believer in using a triple when very low gears are needed, which for me currently is a lot of the time up here in the Pennines!
I don't think I'd like the huge step between the rings on a 50/34 compact chainset - that is 1.47:1. The steps on my triple are 1.33:1 (52/39) and 1.30:1 (39/30).
With my triple, I get a wider range of gears with smaller steps between gears.
If was fit enough not to need very low gears, I'd go for a normal double. When I bought my Cannondale, I was fit enough to get away with its 53/39 chainset on climbs up to about 20% with the help of a 29 sprocket.
Generally true, but I wanted lower ratios on my cassette while keeping inter-gear steps as low as possible so over the years I switched from 12-23 to 13-26 and then to 14-28, the result being that I don't have a particularly high top gear (52/14).The other thing to consider of course, if you are riding in somewhere like the Pennines. Will the 50 on a compact be big enough for the job on the descents ?
