What is that?! And how much out of the piggy bank?300 disc Tiagra groupset
Interesting as someone on another forum said it’s not great spec!From the bikes you've linked the Triban 520 is by several million miles the best spec and the best value. The colour is unfortunate (I came back to road riding 10 years ago with their bright red T3) but the £150 you save from your budget would buy a lot of fluorescent spray paint, glow-in-the-dark iridescent vinyl wrap or sparkly unicorn-poo adhesive rainbow glitter. And you'll have 11sp 105 and semi-hydraulic discs. So buy that one.
Won’t be much commuting as i wfh a lot. And when there is it is pretty much a straight cycle along the beach and then 2 miles of road!If it’s for commuting then one that takes mudguards as a minimum![]()
It's certainly head & shoulders above any of the others you're looking at - I suppose it's not a great spec compared to, say, 12 speed Di2 Ultegra on a full carbon frame with an Enve wheelset - but it's a great entry level spec, certainly compared with most other bikes in the sub £1000 bracket at the moment, and isn't likely to make you wish you'd bought something else. Or be desperate to upgrade to something 'better' in a couple of months.Interesting as someone on another forum said it’s not great spec!
In layman’s terms, what is the difference between hydraulic and mechanical disc brakes? And then between semi hydraulic and the other two?
Cool, thanks. So I may opt for that if I can get over the awful colour! Can you recommend anything similar to the triban? Bearing in mind the ones I linked to were pureful from my novice level knowledge and brief research.It's certainly head & shoulders above any of the others you're looking at - I suppose it's not a great spec compared to, say, 12 speed Di2 Ultegra on a full carbon frame with an Enve wheelset - but it's a great entry level spec, certainly compared with most other bikes in the sub £1000 bracket at the moment, and isn't likely to make you wish you'd bought something else. Or be desperate to upgrade to something 'better' in a couple of months.
I've not used full hydraulic brakes yet but my experience is that in terms of efficiency, cable discs are OK but not massively better than good rim brakes, but semi-hydraulics (which I have on a very silly bike I've recently built up) are a lot better, and mine are a significant improvement on the (very good) Shimano Ultegra rim brakes I have on a different bike. The TRP Hy/Rd brakes on the Triban have been around a few years and are very well reviewed, and a reasonably common upgrade from mechanical discs, as you don't need to change your shifters (typically the most expensive bit of a groupset) for ones with a hydraulic reservoir.
Isn't the black one available?Cool, thanks. So I may opt for that if I can get over the awful colour! Can you recommend anything similar to the triban? Bearing in mind the ones I linked to were pureful from my novice level knowledge and brief research.
The problem I have is I could go round in circles for weeks and months researching but I really just need to get on one and ride it!
Nope.Isn't the black one available?
You might even need an XL or may find it more comfortable.Nope.
Awful blue for the 520 and either a lighter blue or grey in the 500, but not many sizes. I assume i am M or L. Presumably any decent bike shop should be able to measure up and tell me what I am. This is the issue I have with buying online.
A bike shop should be able to, yes.Nope.
I found that the size suggested by Decathlon's chart was too small for me.A bike shop should be able to, yes.
But if you know your height and inseam measurements, then you should be able to work out the right size for you. There are online charts for most manufacturers. Note that different manufacturers size their bicycles differently though, so you can't be sure for instance that the right size for a Cube would be the same as the right size for a Triban.
When looking at the bike measurements, the two most important are the stack and the reach. Stack being the vertical distance between the bottom bracket and the top of the head tube, Reach being the horizontal distance between the same two points. What are the best stack and reach measurements for you though are going to depend very much on your style of riding and your comfort preferences, so if you are getting a bike fit from a shop, you need to be telling them that sort of information.
