Riding in the wet
defy-one
excellent advice Lee
musa
Surrey
Main thing is to keep warm. You'll get wet obviously. But rain and cold don't mix. Some overshoes a jacket a buff and decent gloves
Layers are key
Maylian
Bristol
Overshoes for me and a change of socks for the ride home if it's really horrible. I spent a few hundred on new Altura nightvision wet weather gear and rarely use it as I bake in it.
As for advice, same as everyone else, leave plenty of room behind cards and try and ride in a very strong primary position. When taking corners I tend to block the road completely so I can take my pick of lines avoiding any standing water. As always avoid gutters but even more in the wet as all detritus tends to be washed / pushed that way. High visibility so cars can see you, including reflective's and lights and just enjoy it! I love cycling in the wet, it's only the wind that really bothers me.
Pontefract
Even when lit up like a xmas tree, they still hit you.
Know what you mean about the wind...being wet is ok...jump in the shower after a ride..battling against a strong headwind or being battered from the side = no fun (well just a little!)
Deleted member 20519
Layers are key
My overshoes still let water in and then my toes get cold.
musa
Surrey
Yeah probably after a while. Neoprene material is my preferred choice
I haven't had any problems so far
I still get cold feet. Instead after night and wearing thermal socks. Probably need new shoes that are wider fitting
Kins
Get waterproof socks, even with water in them shoes will retain the heat and keep your toes toasty. I have a pair for hill walking but to thick for wearing with bike trainers I wear so ordered some Thursday. If they are as good as my other ones I'll be quite happy. Still worried about thickness though.
Another thing if you're riding is rain is to remove your crappy stock brake pads. I was complaining that my brakes were spongy and ineffective and I looked at my brake pads (the stock ones) and they'd worn right down due to the horrible weather. I upgraded them to Clarks pads which were two packs for a tenner and wow, what a difference! Braking is now significantly improved in the wet and is even better in the dry. After rides where the weather isn't so nice, I think it's good to clean your rim surface and your brake pads so that they last longer and to ensure you're getting optimum braking performance.
Kookas
Exeter
I can vouch for the Clarks pads, got some on my front wheel. Was hard getting used to brakes that didn't suck.
