livpoksoc
- Basingstoke
Thanks, it s close enough
I would certainly use a cafe lock at any sportive. What's to stop a rider preferring your bike to theirs for example
I have one of these, tiny and much easier than the abus ones
http://www.tredz.co.uk/.Giant-Surelock-Airslock-Loop-Combination-Cable-Lock_68329.htm
Where's the "dislike" button when you need it?!I might have underestimated Newland's Corner. It's not steep, but by goodness it's long.
I'm just going to ask this. For anyone who did it last year, what do you do with your bike if you need a loo break either at the start or during, Just prop it up against the side? I assume there isn't really a need for a lock?
thanks for all the shared advice on this.
i wouldn't have thought to take a small lock, but it does make sense, especially as the ride will be more well known than last year there is always the chance of some chancers targetting it.
my main worry is the cut-off times. i'm starting reasonably late, so there's not much margin for error. my plan is to take it easy until Newlands, but the worry of the broom wagon may change that and i'm not sure i'll be much good if i go out too hard. at the moment the plan is to ride to Leith and worry about the rest after that - it will be 'homeward bound' from there, so i'm trusting my brain will just go into safe mode and pedal (i will have to remember not to turn right at the top of Coombe Hill and go for the real home).
i've also stopped worrying about sponsorship so much now. i had gone for a target of £725, which was the higher one set by Red Cross. if i reached that i received a jersey. as the minimum is £575 and i have achieved that, then i'm not fussed about a jersey. i shall be clad is Euskaltel Euskadi orange (as usual).
good luck to you all. see you in Green Park afterwards for a mass hug.
keep pedalling.
I reckon they pose less of a risk. Your world seems to have much more black and white in it, mine more grey areas.You reckon that the registered riders don't represent any risk?
