r872-Craig
Regular
where did you get the straw? in my r872 cable is rubbing too. Did you ring Ribble?
As promised uploaded some photos.
I phoned ribble and they sent me a straw that should have been used when the bike was assembled.
@George Hotopan
It sounds like it is the rubber BB30 adaptors. I put in a good bit of research and discovered that some adaptors can squeak and creak all day long after fitting, no matter how they are fitted. I opted for the Praxisworks as it is threaded hence eliminating the need for any rubbers or similar which might creak.
Here are some examples to give you an idea:
http://www.bikeradar.com/forums/viewtopic.php?t=12917620&p=18272126
This one has the guy from Praxis works chiming in:
http://weightweenies.starbike.com/forum/viewtopic.php?f=3&t=98394
The Praxis eliminates the BB30 entirely and uses it's own bearings.
http://praxiscycles.com/conversion-bb/
There are others from KCNC, Wheels and FSA but i have not tried any of them.
Thanks a lot Pedro!
I have just ordered the Praxis BB30 68mm from cyclingcomponents in UK. When it arrives I will ask my LBS to mount it for me as I don't have a press fit tool. By the way, did you use a press fit tool or did you do it differently?
What do you mean exactly by rubber BB30 adapters. They are machined aluminium cups the ones I have. No rubber from what I can tell...
I will keep you posted on the topic and as soon as I have the Praxis BB30 converter mounted I will make the R872 some decent pictures
Cheers,
George.
Hi George,
Yeh i press fitted one side which then allows you to thread the other side up to the desired torque. Completely reversible and no frightening talk of locktite!
I was under the impression that your BB adaptors had a hard rubber washer. But because there isn't any tightening then they can move ever so slightly under load, even working loose in some occasions. I believe this has been reported with the Wheels and FSA efforts.
Pics sound good.
Hi George, the O ring will get compressed when tightening the drive side. The video is pretty good.
http://praxiscycles.com/videos/
