Reducing jarring from rubbish roads
Cyclist33
Warrington
My Giant commuter / daily rider has a good frame and carbon forks, and now 3mm Fizik tape. It still runs on 25mm stock Giant tyres. I have brand new Specialized gel mitts which have a lot of thick padding. I mostly ride on the hoods
Other than trying to avoid every drain, pothole, repaired bit of road surface, lump and bump which would be nigh on impossible even if I ride suicidally in the middle of the road, is there any way to reduce the effect of hitting the imperfections (lol understatement around here :laugh:) on elbows, forearms, wrists and hands which can be sore while riding or after any distance (I have had a tennis elbow repair on left arm last November and currently have tenosynovitis in the base of my right thumb).
My Whyte hybrid is better at absorbing the bumps but I don't want to ride it all the time and the carbon isn't practical as a commuter!
go
Different tyres, wheels, something else or just hope the whole country is resurfaced?!
Cheers :smile:
nothing we can tell you will actually help. youll have to try stuff. or pay for a fit. youre not a beginner so you know what your options are. anatomically, not one of our ideas will give your body the answer.
stu
I have discussed fit, hence the new handlebars on both bikes. I discussed gel tape but neither of the two LBS i spoke to felt that this would actually be any better than the 3mm fizik tape, hence having that wrapped.
Other than when hitting the holes, I get little discomfort through my arms when actually cycling. The new gloves were bought following a discussion with my elbow specialist.
I may not be a beginner given I have been riding a while and have had a few bikes, but I am also not technically minded. Hence asking about wheels and tyres, the relevant responses have been most helpful and I shall look at lowering tyre pressure and changing the tyres. It doesn't look like wheels make much difference to comfort, more performance.
I do fear I shall just have to put up with it, unless I change to a bike fatter tyres, although that too comes with compromise.
Maybe I shall start riding on the pavements, as they generally have a much better surface than the roads ;)
SpokeyDokey
Which of the fancy tyres are more puncture resistant?
Michelin Pro4 vs Conti GPS4000? I get the impression from the Wiggle site that these are more racing tyres, so perhaps not very fairy resistant?
How about the http://www.wiggle.co.uk/michelin-pro4-endurance-folding-road-tyre/ ? They sound pretty good http://road.cc/content/review/76068-michelin-pro4-endurance-tyre
If I can find stock anywhere!
Have you thought about these
http://www.chainreactioncycles.com/Models.aspx?ModelID=45443
http://www.bikeradar.com/gear/categ.../product/review-schwalbe-durano-plus-11-44381
mark st1
Plastic Manc
Leafy Berkshire
Retul bike fit worked wonders for me its the appliance of science admittedly and quite expensive but far cheaper than buying a different bike. Ive gone from aching limbs to comfort and the stuff which was changed on my bike was quite vast. I used this bloke but im sure there must be someone closer to your area.
http://adamwhitebikefit.co.uk/
MikeW-71
Carlisle
I'm still thinking it's mostly to do with the tyres. If you don't want to go as far as GP4000S, then 4seasons ones should be similar. Both available on 25mm
Well I rode into London, and was ok especially on cs7 where it is lovely and smooth. I am tired and hot but no worse off than expected. I was going to take the whyte but the wretched fairy decided to visit me 10 minutes from home grrrrrrrr so I went and changed bikes.
I think tyres are the way to go. Comfort, good rolling, followed by p protection. I assume there is no difference between inner tubes in this respect!?
Does that really help with jarring or just road buzz. The fizik tape is 50% thicker than the cheap cork stuff
A Million Dollar question and I don't know. I do remember from test riding some road bikes that 'buzz' varied from bike to bike. I'm afraid it's why I ended up with a steel framed bike but that doesn't help you. A change of forks might do it as well but with personal stuff like this, because every rider has different tolerances, experimentation might be your only option.
