Have you tried a bit of lube (spit) around the valve before connecting the pump?
S screenman Squire 10 Jul 2017 #46 Have you tried a bit of lube (spit) around the valve before connecting the pump?
OP OP GrumpyGregry Here for rides. 10 Jul 2017 #47 screenman said: Have you tried a bit of lube (spit) around the valve before connecting the pump? Click to expand... Tried it once with co2 jobbie. Dull aren't I?
S screenman Squire 10 Jul 2017 #48 GrumpyGregry said: Tried it once with co2 jobbie. Dull aren't I? Click to expand... I wonder if that froze it to the jobbie bit?
S screenman Squire 10 Jul 2017 #49 GrumpyGregry said: Tried it once with co2 jobbie. Dull aren't I? Click to expand... I think you need valves that the cores do not come out of, I will go and check my stock.
S screenman Squire 10 Jul 2017 #50 Sorry only 40mm with non removable valves, Michelin Airstop Butyl.
srw It's a bit more complicated than that... 10 Jul 2017 #51 GrumpyGregry said: Even uglier than me. And that takes effort. Click to expand... A pump that does not pump but is beautiful is not a pump, it's a dead weight. A pump that is ugly and pumps is a pump.
S screenman Squire 10 Jul 2017 #52 srw said: A pump that does not pump but is beautiful is not a pump, it's a dead weight. A pump that is ugly and pumps is a pump. Click to expand... It does pump up, the bad point is it also lets down, quickly.
OP OP GrumpyGregry Here for rides. 10 Jul 2017 #53 srw said: A pump that does not pump but is beautiful is not a pump, it's a dead weight. A pump that is ugly and pumps is a pump. Click to expand... It is beautiful and it pumps.
OP OP GrumpyGregry Here for rides. 10 Jul 2017 #54 screenman said: I wonder if that froze it to the jobbie bit? Click to expand... That time it did certainly.
Wobblers Euthermic Location Minkowski Space 10 Jul 2017 #55 GrumpyGregry said: Even uglier than me. And that takes effort. Click to expand... Ugly it may be, Greg, but it's a fantastic bit of kit. Saved me a few times, and performed sterling service on a few FNRs that I've TECed on.
OP OP GrumpyGregry Here for rides. 10 Jul 2017 #56 McWobble said: Ugly it may be, Greg, but it's a fantastic bit of kit. Saved me a few times, and performed sterling service on a few FNRs that I've TECed on. Click to expand... I have enough ugly but effective in real life to entertain the same a bici. Nu toobs.
