froze
- Fort Wayne, Indiana
As far as a mini pump goes there is none better then the Lezyne Road Drive large size, the two smaller sizes will be more of a struggle. If you already have something like that and she is struggling with it then move on to something bigger.
The other option, howbeit a bit heavier is to use a frame pump, and the best one is the Topeak Road Master Blaster. With this one she should be able to pump a tire up to 100 psi with relative ease. You do have to measure the inside measurements between the headtube and the seat tube, take that measurement and you match it up to their size listings, she will probably need the Small one since she probably rides a small frame bike.
was hoping for a recommendation from a similar sized person
Sadly the bike shops round here don't have a great selection for her to try out
If it's ok with you folks we'll stick within the manufacturers recommended pressures, as I reckon manufacturers will have actually done some testing
& the bike shop she purchased it from recommended 100psi for her weight 👍
