ClichéGuevara
- Kingston upon the River Hull
I can't find the one I had in mind, but I recall seeing a track pump that slotted down the seat post, and became part of the stem, with the saddle itself acting as the handle.
Sweet baby cheeses. What width are those tyres ? 100psi is far too much unless it's like a 12mm tyre.She did try an electric pump from Halfords & it was pretty poor tbh. The bosch may be better quality & worth a look though
Up to press she has been running around 70psi, but recently bought a new bike & recommended tyre pressures are 100-130psi. The shop suggested 100psi for her size & she's happy with them at that 👍
Lezyne, SKS airkompressor, Joe Blow, decathlonIf struggling with a track pump, then I'd imagine that CO2 or an electric pump are the best options for reliable, hassle free inflation.
On the flip side of that I'd be curious as to which pumps are recommended on @vickster's other group - from a selfish perspective an easier to use pump is always a bonus!
I think that is a complete load of tosh!
That weight is per wheel ? So your pressures will be tying in - more weight on the rear than the front.I think that is a complete load of tosh!
Apart from the fact that it doesn't go anywhere near high enough for many larger riders, if it DID then the pressures it would be suggesting would be more than the tyres, wheels, or riders could stand!
At 87 kg, I use pressures which on that chart are suggested for riders between about 47 kg and 50 kg!
I'll rephrase what I posted...That weight is per wheel ? So your pressures will be tying in - more weight on the rear than the front.
Gosh, what useful input. So it's "tosh", and it's "what you use".I'll rephrase what I posted...
Given that the graphs actually refer to wheel load, I'd say that the figure for the rear wheel is about what I use.
He just didn't get how the chart worked beforehand. So if you look at the chart - there's no way a 50kg rider needs 100psi.Gosh, what useful input. So it's "tosh", and it's "what you use".
Don't think I'll be coming to you for tyre pressure advice
As cougie says... I made a mistake. Which I then openly admitted.Gosh, what useful input. So it's "tosh", and it's "what you use".
