Recommend me a pump for a lightweight
Soltydog
near Hornsea
Hi all,
I'm looking for pump options for my better half. She's rather petite & at 45kg she can not physically pump tyres much beyond 70psi with my track pump :blush: Any other lightweight riders have a track pump or similar that is suitable for a smaller person getting tyres upto a decent pressure?
TIA
Google suggests a pump with a narrow barrel and that the high capacity Lezynes are easy to use :okay:
https://www.sigmasports.com/item/Lezyne/Alloy-Floor-Drive-Track-Pump/G14Q
Soltydog
Soltydog
near Hornsea
Cheers Vickster, I'll struggle to convince her from a google recommendation :okay: was hoping for a recommendation from a similar sized person :laugh: Sadly the bike shops round here don't have a great selection for her to try out :sad:
It was from a road CC review. I’ll ask on the Velovixen FB group (a great resource for women’s cycling if your wife is interested)
Unless @Reynard who is petite has a suggestion?
Soltydog
Soltydog
near Hornsea
How about an electric pump like this:
She did try an electric pump from Halfords & it was pretty poor tbh. The bosch may be better quality & worth a look though :okay:
Can't you pump your own tyres up? At 45kg hers won't need more than 70psi!
Up to press she has been running around 70psi, but recently bought a new bike & recommended tyre pressures are 100-130psi. The shop suggested 100psi for her size & she's happy with them at that 👍
Thanks. She's on that group so she can always ask herself :okay:
Done anyhow!
Sharky
Kent
100-130psi does seem high. I'm 82kg and even on my tt bike, with 20mm or 23mm tyres, rarely go above 100psi and the tyres feel rock hard as well.
I don't put in more than 100 PSI with 25c, so 70 will be fine. What about a Topeak Road Morph G (Gauge). I have one and it's great, but can't say if your wife will struggle with it - it's a mini track pump.
Scotchlovingcylist
Formerly known as Speedfreak
I've a joeblow which I find the easiest to inflate out of the track pumps I've owned.
My daughter can use it to inflate her swimming pool, footballs etc which I appreciate are different.
Maybe try a way to get more downward force for her or fettle a wider pump handle if a better pump cant be sourced
