roley poley
- leeds
why are chargeable batteries 1.2 v and throwaways 1.5v???...does it make any difference to the choice on this thread versus output for a light ???
Batteries, whatever sort, have a life that is often shorter than the lights they're fitted in. Rechargeable batteries that can be recharged, sometimes in the lights, but aren't sealed in, are the halfway mark.why are chargeable batteries 1.2 v and throwaways 1.5v???...does it make any difference to the choice on this thread versus output for a light ???
Chemistry.why are chargeable batteries 1.2 v and throwaways 1.5v???...does it make any difference to the choice on this thread versus output for a light ???
A viable white LED, Shuji Nakamura.[QUOTE="andrew_s, post: 6581003, member: 187"
It's unlikely to make much difference in an LED light. In old bulb lights 1.5V would be brighter
whoever invented the L.E.D deserves a medal
If you are regularly going to be riding longer than a single charge worth, then the ability to swap out one set of rechargeable batteries for another is an advantage. If you aren't, then IMO USB has the advantage, because no need to faff around opening the light and taking the batteries out to charge. But that is my personal preference.
Well most of my riding is on pitch black unlit rural roads - and in winter there is often no moonI can't see many instances where even a long night ride is going to deplete a fully charged USB light. The cheap & cheerful Crivit USB rechargeables I use will run for well over 10 hours on their low setting if starting out from a full charge. I've tested the things indoors just to see how long they run for, and was getting bored by the time they ran down. Unless you are riding all night on pitch black unlit rural lanes on a night when there's no moon, you don't need the high output settings so the lights would last from dusk to dawn if needed. That's from a £13 set of lights courtesy of Lidl.
I'd expect more than 2 hours from a decent light. I suspect a lot of the light from your 1600 lumens is shining other places than on the road.Well most of my riding is on pitch black unlit rural roads - and in winter there is often no moonSo I do use it on full power a lot of the time (1600 lumens, enough to be reasonably comfortable at 25mph).
But even on full power, my light lasts around 2 hours, and I am very rarely out longer than that, particularly after dark.
Well I have never actually ridden long enough to be sure how long I would get.I'd expect more than 2 hours from a decent light. I suspect a lot of the light from your 1600 lumens is shining other places than on the road.
The Lidl lights (at least the older ones which use the german beam standard) would do better than that.
I have ridden the Dynamo night ride on a Lidl light.
How do you find the beam pattern on the Vision 1?My main lights are a hope vision 1 (front)
another reply to this - those batteries are a bargain - I just had a look and it lists the 2450 batteries as new which is kinda odd as I have had a set for a fair old while. Not sure what could have changed? I do a fair bit of through-the-night riding and mistakenly bought 2 sets of four batteries from 7-day shop which are labelled as something super impressive like 2900. But they aren't low self discharge - I am forever recharging them before one of my night rides - I wouldn't be surprised to learn that they drop to something less than those IKEAs soon after being taken out of the charger so all a bit pointless.Just had a look at the IKEA site. It is showing two types of AA batteries, one type are 1900 Mah at £4 for 4 batteries, the other type is 2450 Mah at £6.50 for four. The pack of eight CR2035 for £1 looks a bargain.
I think I remember that one way of telling that the IKEA batteries were the rebadged Eneloops was the country of manufacture being Japan.
A pity - was well worth developing I think.I think it may well be discontinued.
I've seen a few tests of rechargeable batteries and the stated capacity is often " optimistic " There's a YouTube channel by Big Clive, he took an Eneloop apart :another reply to this - those batteries are a bargain - I just had a look and it lists the 2450 batteries as new which is kinda odd as I have had a set for a fair old while. Not sure what could have changed? I do a fair bit of through-the-night riding and mistakenly bought 2 sets of four batteries from 7-day shop which are labelled as something super impressive like 2900. But they aren't low self discharge - I am forever recharging them before one of my night rides - I wouldn't be surprised to learn that they drop to something less than those IKEAs soon after being taken out of the charger so all a bit pointless.
