DSK
Thanks @Ajax Bay that Hambini link is very useful and I found this also
View: https://www.youtube.com/watch?v=E-FqWpi5n8Y
What does Prolite suggest is the function of oil in spoke nipples?water may be removing the oil in the spoke nipples.
I wonder what adverse effect would reduction in oil (if there at all) have on the function of the (assume properly tensioned) spokes?
Oil? Maybe a dab of grease to make sure they tighten up smoothly and unscrew down the road.
I'd be interested to know what spoke tension you have in that back wheel. It should under no circumstances be flexing laterally under any type of load and spoke tension will impact this.Some wheels are really flexy. I can't use the 28T sprocket on the Boardman because, under climbing stresses, it rubs on the spokes. It's well clear of them when stationary. Not much I can do about it; it's a function of flange spacing and spoke count. Spoke tension barely affects stiffness.
It's a factory DT wheel, 28h. Fairly conventional apart from the nice DT/Hügi hub. The only wheels I own out of...er...about 40 that I didn't build myself.I'd be interested to know what spoke tension you have in that back wheel. It should under no circumstances be flexing laterally under any type of load and spoke tension will impact this.
Flange spacing impacts the dish of the wheel and consequently impacts the length of the spoke but as far as I understand it this should be accounted for in the wheel build itself.
Let that be a lesson to youIt's a factory DT wheel, 28h. Fairly conventional apart from the nice DT/Hügi hub. The only wheels I own out of...er...about 40 that I didn't build myself.
I know, I know. It was cheaper than buying two DT RR rims, Shimano hubs and spokes, which is what I should have done 😭Let that be a lesson to you
[Prolite suggests that] if water gets into the spoke nipples it starts to corrode them inside (despite them being greased/oiled).
