DSK
I have a new ProLite wheelset fitted to my Propel. I have covered about 50 miles on these wheels and the bikes been flawless.
2 days ago, whilst parking the bike up, I was changing the gears on it whilst using 1 foot to spin the crank, 1 hand lifting it off the ground by the seat and 1 hand doing the gears. Whilst the rear wheel was spinning it caught the cycle stand with the spokes. The wheel kept turning so it wasn't bad but did flick the bike slightly in my hand.
The next day on the morning ride, the bike wasn't quite as effortless as it usually is and I noticed an occasional click/click during crank rotation. I thought this may be something developing in the drive train and carried on my ride thinking I'll check it when I get home.
A bit of brake rub evidence on the rear rim. When bracing the bike with your body, if you wiggle the rear tyre at the top, it moves left/right. The occasional click/click noise turns out to be the rim contacting the brake pads on one side, depending on which the wheel moves. The spokes and nipples all seem fine. I removed and refitted the wheel to ensure it hadn't moved in the drop outs. But the movement is still there and I know its not the bearings. Any ideas on what could have happened causing the movement?
