mickeydrippin60
- bolton
A 'cog' is not a gear. A combination of the large(st) chainring and the smallest sprocket affords one the longest and highest gear. A combination of the small(est) chainring and the largest sprocket affords one the shortest and lowest gear (for climbing).
Bottom cog? 1st gear? AASHTA
"Gear Numbering
People often want to number their gears sequentially, and will sometimes speak of "7th gear" or "13 th gear." There is, however no standardized way to designate gears in sequence by a single number. If you wish to give your bike's gears sequence numbers, that's fine, but don't expect to be able to communicate with anybody else using those numbers."
Stop being a pain in the arse it's quite obvious what he meant Just because you don't like the way he said it doesn't mean that it's wrong
