Rear Light Positioning
youngoldbloke
On my bikes the slightest knock would push the light into the spokes. If you've got enough clearance suppose it would be OK.
downfader
extimus uero philosophus
'ampsheeeer
Why is it a bad idea to mount one on the inside seatstay?
From experience - if a light comes loose it will bounce off the spokes anyway. Usually disintegrating. Doesnt matter where on the stay its positioned really.
Scotchlovingcylist
Formerly known as Speedfreak
Fair enough never gave it much thought. There is a fair bit of clearance tbh with it being a mtb however those planet x brackets are garbage
downfader
'ampsheeeer
Glue some old inner tube on the face of the bracket where the clip on the light touches? Might stop slippage a little ....EDIT: also some threadlock plastic on the bolts might help a touch
Anyone seen those hood things that fit over the rear light and diffuse the beam? I think I've seen one with a sort of opaque crud catcher.
