Rear Light Positioning
steveindenmark
I like how your user name's "Steve in Denmark"
Then you post that you're in Denmark and sign your name.
Glenn, when you are as old as me, you can repeat yourself as many times as you want.
As you want.
SteveinDenmark
P
pjminton5
Stockport
Wow! Thanks for all the help and replies. Problem solved. I've scrapped the saddle bag and I now have a tool bottle which I keep spare inner tube, levers, multi tool, and repair kit in. My lights are knog blinders and the strap is only designed for my seat post. Also I might get a different mud guard soon as it is off my mtb.
Ian193
Wow! Thanks for all the help and replies. Problem solved. I've scrapped the saddle bag and I now have a tool bottle which I keep spare inner tube, levers, multi tool, and repair kit in. My lights are knog blinders and the strap is only designed for my seat post. Also I might get a different mud guard soon as it is off my mtb. View attachment 53768 View attachment 53769
Could you not fit the light to the top of the tube that the seat post comes out of then the bag should still fit that's how I fitted my comet rear light to my bike and it works fine
brand
Put a nicelite bulb in an old Ever ready rear light. Previous bulb was Halogen 14 Lumens, replacement is 110 - 120 Lumens LED.
FOG LIGHT!!!
BSRU
A Human Being
Swindon
If your using a carradice saddle bag support of some kind you can attach it to the support.
MontyVeda
There are always bodges you can do to get lights to fit
Mine involved a handful of cable ties, the side of an old 35mm film canister, and the lid of said canister...
...to attach two lights to the back of my saddle bag. One points straight back, one slightly up, both are well out of the coat-zone and high enough to be seen over car boots & bonnets.
I made a little bung with a hole through it for a screw and drilled and tapped a hole in the base of the saddle to make a mount for my cateye rear light so that it would sit above the saddle bag. I have ridden behind people that have them below the bag and the bag can obscure the light.
I use 2 lights as I have found the cateyes to not be the most waterproof lights on the market. Best to have a back up.
Like it. Having just spread the innards of my cateye rear light over the road (it was "attached" to the light loop on the very same topeak bag as yours), i need a new way of attaching my new one (which is also the same as yours)
Scotchlovingcylist
Formerly known as Speedfreak
This is my setup. I like a light on the seat stay as well. I also have one on my rucksack and used to have a pound shop one on the saddle bag until it bounced off under a bus
youngoldbloke
Maybe that's why I have a problem mounting a light on the seat stay - I would never mount a light on the inside of the seat stay, IMO it's an accident waiting to happen, and all the brackets I had with lights have been like the one above. Perhaps they are designed for Europe and the US where you would mount the light on the non drive side?
