Rear Light Positioning
pjminton5
Stockport
Ok, so I'm new to road cycling/commuting and I am after some tips/advice please.
I have a saddle bag fitted but am unable to position my rear light on my seat post in a place which makes it visible, it is hidden underneath the saddle bag. So my question is do you guys not tend to bother with a saddle bag and if so where do you keep your spare tubes and tools etc. Thanks
youngoldbloke
You can clip (some) lights to (some) bags, but seldom end up with the light pointing in the right direction. The other place could be the rear offside seat stay, but it might mean a lot searching to find a bracket that works in that position.
w00hoo_kent
One of the 64K
I don't do seat bags.
Aside from attaching the light to the bag you can also clip some to yourself when I wear a helmet it has one on it.
One of the vertical cats eye style ones might show below a bag, there might also be options to attach to saddle rails.
cyberknight
Most lights you buy come with a bracket for seatpost and seatstay.
I've fitted lights to the seat stays before now.
I also used one of THESE when I very briefly used a rack and panniers.
400bhp
I'm not sure most do come with a seat stay. Most default to seatpost.
There's a fairly common standard bracket that if you look around you can find a type that has, what I can best describe as a watch type strap. They are ideal for locating on the seat stay. Example of bracket is here.
Soltydog
near Hornsea
I normally fit mine on the lower part of the seatpost. That way its not obstructed by my small saddle bag or mudguards. It amazes me how many people have their rear light obscured, normally by a crud catcher style mudguard. Once saw a guy leaving the train station wearing a black leather trench coat that covered his rear light, I mentioned it to him, but he just replied that his light was on :wacko:
steveindenmark
I wear a vis vest and have stitched a small piece of webbing between the shoulder blades where I wear a flashing Smart light. A light is also attached to the bike.
I think it is a good idea to have 2 lights to the rear, especially having one higher up as it can be seen by traffic if they are queuing behind you as they cannot see the light on the bike.
Steve
Shut Up Legs
Down Under Member
I have a rear light clipped just below my saddlebag. It only needs to be just below the saddlebag to be easily seen by traffic behind you. The picture below shows my bike with its current saddlebag. The light I'm currently using clips to the seat post just above the reflector and below the saddlebag.
