Andrew_P
In between here and there
Help!
I am having an on going issue with my SuperSix Evo.
The two rear dropouts are different sizes consequently when I put the wheel so it is flush the wheel sits far too close to the drive side chainstay the only way I can get it to sit straight is to have it slightly away from one side and close the QR as tight as I dare. Sometimes its stays straight other it returns to flush and rubs the rear drive side..
The Frame has been back to Cannondale but they deny a problem, or if there is one blame it on the bike having been run with a loose QR which I deny. There are no marks on the dropout that suggests any problem no non smooth bits and all still painted and if the wheel is in without the QR there is full movement loose on one side. The difference at the widest point is around 2mm
Two things should I pursue Cannondale further or is there a simple fix?!
