matticus
they seem very graceful but that tip speed s fast
Certainly is! About as quick as a Peregrine Falcon*
*discuss ;-)
Great factoid though, I would have estimated maybe 80mph for the big ones?
Without getting your calculators out first - which of these has the highest speed at the tip ?
v
v
v
v
v
v
v
v
v
v
v
v
v
v
v
v
v
v
v
10" bench saw 3800 rpm tip speed 113 mph
90m wind turbine, 26 rpm = tip speed 275mph
Can't see that last bit adding any real amount to the total.That would be some spectacle. When you say 8 billion people would only produce 4 billions of gallons of pee, that’s half a gallon each. I need to drink more.
thats what it says for the ones I was nearThey are impressive bits of kit.
26rpm is pretty quick for a large wind turbine. Does the UK have any on shore turbines with 90m blades?
Abd they won’t be reaching that speed often. for most of their operating time they will be running much slower.
https://www.thewindpower.net/windfarm_en_22027_barmoor-south-moor.php
I counted 26rpm (used a video to be accurate) other data says they need to operate between 10 and 25 rpm to be efficient ?
so even at (25+10)/2 = 17.5rpm that would still be a whopping 185mph
just looked up biggest offshore the MySE 22MW turbine - 310m dia blade (do you think that is a made up figure, 310m ?) anyway it doe 10rpm and will have a tip speed of 365 mph
i do hope my maths is right with this (someone should double check)
Incredible speed. I also read that each revolution is enough to power a typical UK home for 24 hours.
*discuss ;-)
On a slight tangent, I was at a place where a man was looking through binoculars at a nearby building. He said he was disappointed as he'd only seen the one, yet he was assured that there was a pair of green falcons nesting there.![]()
