Dave5N
- Outside The Little Nibble
Snob
ian_oli said:Decathlon cheapo inner tubes.
Rhythm Thief said:Mine worked ok - I used it to raise my LEDs above my bar bag - but it's just such an ugly thing. It looks so cheap and nasty.
llllllll said:The plastic bracket Cateye supply with their lights. Few years back the were done up with a small screw and worked perfectly. Nowadays you have a little plastic dial thing that you have to turn. It's badly positioned and too small to get any force on, so the light slips as soon as you start cycling. In an effort to get more force on the dial I've tried putting Molegrips onto it, but then it just chews up the notched strap thing. In the end I had to glue the bracket onto my handlebars to make it work.
Biopot with wholegrains is worse...TheDoctor said:Depends what you're lubing, surely?The seeds in strawberry yoghurt are a bit scratchy, I always find...
Tim Bennet. said:anyone possessing the mechanical acumen of a drunk baboon or better, should be able to put them on without much trouble.
Second vote goes to the inside chainring bolts with those two small slots and the virtually useless tool which is supposed to hold them still.
Trillian said:the one thats like a little QR lever? works beautifully on mine, was swapping it between two bikes quite regulally at one point.
alecstilleyedye said:i forgot the bikemate saddles and saddlebags - you can't use one with the other if you have a micro adjustable seat post (anyone here still using the old fashioned clamp?).
Only cos I'm waiting for someone to give me a 25.2mm seatpost with a "modern" clamp ... been waiting about 9 years ....
