PatrickPending
- Leicester
a chain whip and a cassette remover.... its quite easy to do to be honest so worth a go if you want to invest in the tools..
I have thisYeah that's what I was thinking after ding some research. Does replacing a cassette require a special tool?
the cog on the right is worn the one on the left isn't
Don't sell yourself short. I think you did very well. Indexing can be very dicey when more than one part is not where it should be including cable tension.I can change tyres, fix punctures, clean it and fit/change various parts...but indexing....it confuddles my brain!
Well, I gave in. I can't bloody index gears!
I ran it up to my LBS in the car, where they had it on a stand and sorted in about 2 mins.
I am forever disgraced and we shall not mention this again
Help! I don't know whats going on here.
I fitted a new chain yesterday. The gears had been a bit lumpy - changing from 2 to 1 was a pain and it rarely dropped into gear unless I was going at speed, and changing up from 1 to 2 needed a second nudge of the gear shifter to drop it in.
I adjusted the gears the way I thought was right, but it's worse than ever!
Just had it out a test run and as I'm pedalling the gears are jumping about!
It's on the stand now and I've taken a picture.
The chain is rubbing against the far side of the front derailleur (that's the part right?) and also rubbing the tyre!
What's going on and how do I sort it. I need the bike for tomorrow and as it stands I can't ride it!
