Thanks again for the considered and comprehensive replies. But i'm tending away from chain length (and possible rear mech) as a diagnosis.
The reason is that this morning i have replaced the 50/34 GXP with the old 48/34 ISIS and i can still not get consistently into large/large. This is with the bike back to original spec, except for the cable change that i did to accommodate the stem riser.
On both set-ups i can go large/large only by dropping into the small front first and then changing to large/large using the front derailleur.
Once i have done that, still on the large front i can change up to the second largest rear and then back down to the largest. But only once!!! If i change back up to the second largest rear and then attempt to go back down to the largest again, it won't do it. It sounds crazy but i have repeated this sequence three times and it's been the same each time.
EDIT: Now it won't go on to the rear large on either front chainwheel.
