Most of CAM works on about that levelIt would be interesting to see them react if their GP started prescribing untested drugs on the basis they believe they are good.
Medicines are another excellent example where the .......
Take this because it's good for you, and will help your condition
Forgetting to state that 10% of the patients will have a cardiac arrest and another 5% headaches and respiratory problems.
... and of course if you point this out to the patient you will be anti-health!
Utter rubbish - side effects should be carefully explained to the patient, and I have no doubt this does happen in the vast majority of cases.
All medication comes with a patient information leaflet listing all of the known side effects.
in the taped visits, doctorsexplained an average of 3.1 out of the five instructions. The name of the drug was explained 74 percent of the time and the purpose was given 87 percent of the time, but side effects were only explained 35 percent of the time. Including the results of the patient surveys, the researchers found that physicians gave full medication dosing instructions for fewer than 60 percent of prescribed medications, and informed patients of side effects and how long to take a drug about one-third of the time.
I am glad you have such a vast experience of the medical profession and how they prescribe drugs.
The operative word is SHOULD, but in busier and busier clinics, shorter appointment times, and greater pressure to see more patients, shortcuts are made and this is one.
The sad fact is that it IS the case.
Take "non-compliance" and you will find that the single biggest factor appears to be a failure of the prescribing doctyor to describe the drig, how to take it and the side effects
Typically in 2006 Tarn and his co-researchers taped 44 outpatient clinics and showed that:
This is merely anecdotal, but I have *never* had an NHS doctor explain side effects of prescribed medication to me. This includes meds for myself, Miss Canrider and Master Canrider. Now, I've always let it slide because I know I can a) read that leaflet, b) I'm savvy enough to have a working idea of what a corticosteroid/antibiotic/brochodilator is likely to do and c) I know I can look it up on t'Internet for myself when I get home. But no GP has *ever* tried to explain these things to me, ever.Utter rubbish - side effects should be carefully explained to the patient, and I have no doubt this does happen in the vast majority of cases.
Box 1: Relatively common prescribing errors
- Poor compliance caused by prescribers failing to elicit patients' preferences and beliefs about medicines
 - Poor compliance caused by prescribers failing to explain why a drug is being prescribed and how it is supposed to work
 - Inappropriate drugs or dosages caused by poor communication between doctors about contraindications or adverse reactions
 - Failure to convey essential information to patients about how and when to take their drugs
 - Failure to discuss common side effects, so that patients are ill prepared to cope with these and to recognise unexpected problems
 - Errors resulting from problems occurring when medical records are transcribed (these could be avoided if patients were encouraged to check their notes)
Red Light, you have derailled this interesting thread about helmets! I think you might have done it deliberately![]()
Compulsion is a big issue and one that is uncomfortable for many and hence wish to hide it as a subject.
