addictfreak
- Boldon, Tyne and Wear
Never had any problems whatsoever with prestas, in fact i prefer over shraeder valves. I use a track pump at home, and have a cheap topeak mini pump with smarthead fitting, which does a great job.
Kaipaith said:Bought myself a track pump yesterday - haven't tried it yet. The old tube seems to be holding its pressure well, so as long as it lasts until the weekend, I'll switch the tubes then... fingers crossed.
Kaipaith said:OK, so I got my new bike last week. I love it - but the tubes are Presta valves, and I've never used them before. I figured I should acquaint myself with them... and I seem to be incurring problems.
First off, I'm using a hand pump. I know I should get a foot pump with a gauge, but after the expense of the new bike I simply couldn't afford it. However... Every tube I've tried, I could pump it up to a certain pressure, but no more. Not as firm as the other tire, but firm enough. Fine - I remove the pump only to find the screw and nut on the end of the core is missing - sheared off. I'm fairly confident I wasn't wiggling the pump around THAT much.
This has happened on three tubes, I've just used my last one. I'm kicking myself, I really am. I now can't tighten the nut to restrict airflow. I would suspect that the airpressure would hold the valve shut, but even if so, I wouldn't want to commute on it too far, and I would want to know what I'm doing wrong anyway!
orienteer said:I bought one of these when my track pump connector wore out:
http://www.inmotionproducts.com/pro...3d2580ebbd2bb318939e7316a&text_product_id=THA
Kaipaith said:The valve is straight, but the but the end of it with the pin which allows airflow, and the nut which holds it in place, has been sheared off.
