amaferanga
- Bolton
Power2max looks like it is around 1100 euros and the first generation had a few issues with changes in temp.
You can't buy a first generation one now (and even if you bought a used one you could send it off to get the update). I bought mine in September 2012 and it had the temperature compensation stuff so this is simply not an issue with P2M any more. Also, you could get a SRAM S900 version for about £750 and then source a crank for about £50 so that's more like £550 saving on Vector.
I'm beginning to bore myself here banging on about the Vector, but I'm just not getting why folk are so excited about it. If it was £600 then I'd agree, but it's up there with the more expensive power meters. I'm sure it is or will be after the bugs get ironed out a good power meter, but it's neither better value, more convenient (6mins to swap over accordning to dcrainmaker and requiring a torque wrench and a special tool - my P2M takes <2min and I only need an 8mm hex bit) nor better featured than other power meters that are available. If you like it then buy it, but its just another power meter.
