Im not being funny but that sounds like you are taking up all of a Lane on a Dual carrigeway.
Assuming that is what is meant - and that is certainly a reasonable assumption - what is wrong with that?
I don't ride on dual carriageways, precisely since I think the above is what a cyclist should do; they
should take up the whole lane and oblige cars to overtake properly in lane 2, lane 3, etc. Unfortunately, I don't trust all vehicle drivers to recognise that they need to change lanes to overtake so I'd be uncomfortable doing that and I therefore don't ride on them other than very briefly for short distances when essential.
The alternative (to taking the lane) is to cycle such that a vehicle traveling (legally) at up to 70mph can pass within the same lane whilst being overtaken by another vehicle. That is, to say the least, not an appealing situation for the cyclist but is bound to arise unless the cyclist has emphatically 'taken the lane'. If I'm on a bike I want vehicles traveling at that relative velocity to be in their own lane, hence the strong primary position is required, but since most cyclists will hug the edge, most motorists will in turn assume that they can overtake any cyclist within lane 1 and will not be anticipating the possibility of a) moving out in good time into lane 2, b) slowing to the speed of the cyclist if they cannot move into lane 2 due to traffic approaching them from behind which is already in lane 2.
Given the standard of anticipation of at least some drivers (not considering the road far enough ahead), combined with the lack of familiarity with the idea of a cyclist 'taking the whole lane' on a dual carriageway, I don't see a safe solution, which is why I avoid them. That's relatively easy to do around here, but clearly isn't in many places.
This is yet another of those things that needs behavioural change on both sides:
- drivers need to recognise that they should change lanes, not merely shuffle out slightly, to pass cyclists, especially at high relative speeds;
- cyclists need to 'take the lane' to compel this behaviour.
I can't see either of those happening in a hurry though
On the OP's original point: I agree that there definitely does seem to be a psychological reticence in some drivers to crossing the white line at all, and if they are forced to then they are more likely to completely change lane. That's a definite advantage of 'strong primary', but fails to address the issue of those drivers not paying attention to the potential need to do so.
